Home Forums Products Stompboxes TF modulation question Reply To: TF modulation question
#120262
achaput
    It works this way because many people like to turn the delays to 0ms and use TimeFactor as a chorus pedal. It is still only the delays which are modulated, but when the delays are at 0ms you hear them at the same time as the dry signal.
    If you want to completely bypass the wet on one channel, a splitter and A/B switcher could achieve that effect.
