Home › Forums › Products › Stompboxes › ModFactor Bypass – Delayed activation of effect › Reply To: ModFactor Bypass – Delayed activation of effect
April 8, 2010 at 9:09 am
#120264
I'm using 2.0.2[3] but I dunno if it's got something to do with the issue, probably hardware related?
All of these happens either in Bank mode or Play mode. Only in Bank mode, if you alternate between left and middle switch (to select preset 1 or 2) there's no delay. But if you turn off say the left switch then switch it on again, the "short delay" happens again. And again this is in DSP bypass mode.
Do you guys think this is normal? Cause I just bought my ModFactor so it's new and I'm worried that this is not how it's supposed to be. Thanks!
