Home Forums Products Stompboxes ModFactor Bypass – Delayed activation of effect Reply To: ModFactor Bypass – Delayed activation of effect
#120265
sic
    I'm running my ModFactor on 2.0.2[3] btw, but i dunno if that's got somehting to do with the issue.
    This happens in both Play mode and Bank Mode (DSP bypass). Only time it doesn't happen in Bank mode is when you alternately switch between the middle and left switches. But if you say, turn off the left switch and then on again, the "short delay" happens. Again all of these happens only in DSP bypass mode. When it's on Relay mode there's no problem. Anyone care to comment?
