Home Forums Products Stompboxes pitchfactor pitchflex when pitch is set to ‘off’ Reply To: pitchfactor pitchflex when pitch is set to ‘off’
#120277
I'm looking for workarounds.  If you use an external switch you can map it to pitchflex and wet/dry mix- as soon as you step on the switch it kills dry and the pitches changes at the determined rate. I haven't tried it yet but think it should work.
Seems like this would be an easy software fix – let's make some noise!
