Home Forums Products Rackmount H8000 Midi Problems Reply To: H8000 Midi Problems
#120349
steveevans
Hi Italo,
I'm running v5.3.
I've looked into this a little bit more and it's a bit weird. Here's what I have on one Little Giant switch:
Midi ch 1, CC 0 35
Midi ch 1, PC 10
Midi ch 2, CC 0 35
Midi ch 2, PC 10
If I understand this correctly it should load preset 3510 on both DSP A and B. What I find is this though:
1) The first time on DSP A, it selects preset 10 in the current bank. But the second time it works fine. If I then load another preset using the front panel into DSP A from a different bank and try from the Gordius again, I get the same issue i.e. it works the second time.
2) CC 0 35 on Midi ch 2 (DSP B) never works for me.
3) When I originally did the test I arbitrarily chose preset 3610. For some reason I cannot get the H8000FW to select bank 36 at all on either DSP.
I haven't looked any more into the dual virtual racks tweak problem yet.
It may be a problem with the Little Giant, I'm not sure. Any idea how I might debug this?
Cheers. Steve
