Home › Forums › Products › Stompboxes › Eventide Tap Tempo with a switch through Ground Control Pro › Reply To: Eventide Tap Tempo with a switch through Ground Control Pro
May 2, 2010 at 8:55 am
#120371
Is that confirmed? If The Ground Control is able to send midi to tap tempo with their instant access than shouldnt converting an actual tap tempo midi data through their expression pedal be simple enough? Its just momentary switch as opposed to the expression pedal function.
K, hv written on their forum…will update here once i have a confirmation.
