Home Forums Products Stompboxes Can Stereo Outputs on Mod, Time & Pitch be plugged in, but not engaged? Reply To: Can Stereo Outputs on Mod, Time & Pitch be plugged in, but not engaged?
#120491
Thinking about this some more, what happens when they're all wired for stereo (2 leads/2 outputs) but only 1 lead ends up going to the amp (in the case of a mono amp)?  I understand that the panning and effect itself won't be stereo, but would it still effect the signal enough to run in a mono parallel loop??  Or would the pedal simply not operate whatsoever?
Thanks,
Mo
