Home Forums Products Stompboxes HOW GOOD is the buffering in Active mode on the 3 ‘Tide Stomps? Reply To: HOW GOOD is the buffering in Active mode on the 3 ‘Tide Stomps?
#120502
BLooDRuST
I have a Metro Marshall 1968 SLP (plexi replica) which I had modded with
a master volume and an FX loop. When I had the guy do the FX mod I told
him that I wanted it set up for my (vintage) Eventide H910. I ended up
selling the 910 and hadn't much use for the Fx loop since I was using a
Line6 and MXR flanger, (both of which sounded better going into the
front end of the amp). I here to say that not only does the Pitchfactor
sound amazing but it lines up perfectly with my FX loop and the amp is
actually quieter with it in there as well. That being said, I also have
been using some buffered looper pedals which helped a lot regarding the
levels, presence, etc; however, since I set up the Pitchfactor (with
it's buffering) in the FX loop I no longer need the buffered pedal. This
stomp is really and truly amazing. Amazing. This little stomp is
absolutely a keeper. Thanks Eventide!
