Home Forums Products Stompboxes Gigrig midi control for Timefactor/Modfactor Reply To: Gigrig midi control for Timefactor/Modfactor
#120506
    As far as I can see, the Pro14 has no MIDI capabilities, so I assume you are trying to use the foot-switches.
    Your problem is probably that you are using the MIDI settings (e.g. RCV CTL) when you should be using the AUX SW settings.
