Home › Forums › Products › Stompboxes › original power adapter delivering 12v › Reply To: original power adapter delivering 12v
June 17, 2010 at 7:40 pm
#120513
So is it feasible to run TF from the 12V outlet of a Fuel Tank to take advantage of the high current availability? I accept it is outside the recommended ideal, but some quick sums would indicate wall voltage fluctuations of approx 30 volts worldwide means the pedal should be able to handle it??
Thanks for any advice
