Home Forums Products Rackmount Eclipse signal level Reply To: Eclipse signal level
#120567
    You should probably keep to the 1/4" cables – there is no obvious reason to go from 1/4" to XLR when you have the 1/4" connectors. Also, the 1/4" input has much more gain, as it is designed for guitar use.
