Reply To: Spill?!
Home Forums Products Stompboxes Spill?! Reply To: Spill?!
#120571
harristablist
thats not exactly what i want, i need it to have fadeout trails and the trails to continue uninterupted even when switching presets and then whenever the next sound is played the new delay kicks in like normal(no fade in) but this having the same trails.
Can you add an extra option within an update?
My only quarms with it are as follows say I'm using a slow delay and a fast, using the slow one first, hit the middle switch and the trails will jump to the next delay fast trails, this is pretty useless in my oppinion.
The bypass fx setting for the bypass switch seems fine on how i think it should operate but the switching of presets cracks the trails on this setting. if this could be applied to the spill, id be happy, Basically if the spill acted like the bypassFX setting in normal mode, while switching presets. NICE!
