Home Forums Products Stompboxes can i use a Ground control to…. Reply To: can i use a Ground control to….
#120601
    You may be able to do this if you understand the use of MIDI maps (and set all the pedals to the same MIDI channel). You will probably also need to set some or all of them to MIDI THRU if you plan to use a "daisy chain" connection.
