can i use a Ground control to….
Home › Forums › Products › Stompboxes › can i use a Ground control to….
    • #107177
      I love my new stomps but would like to do patch changes across 1..2..or all three at a time. can i do this with a ground control?
      thanks kurt
    • #120601
        You may be able to do this if you understand the use of MIDI maps (and set all the pedals to the same MIDI channel). You will probably also need to set some or all of them to MIDI THRU if you plan to use a "daisy chain" connection.
