Home Forums Products Stompboxes Assigning more than one external controller to a parameter Reply To: Assigning more than one external controller to a parameter
#120603
cscotto
    Thanks for the answer. I knew I wasn't crazy. Connected directly to the TF, the expression pedal works just fine. I needed to calibrate the expression pedal on the Midimaster, which improved the problem. It is not perfect, so I will contact RJM for a solution. All the best,
    Ciro
