Home › Forums › Products › Stompboxes › TimeFactor Cycles On/Off › Reply To: TimeFactor Cycles On/Off
July 22, 2010 at 3:45 pm
#120606
These power jacks are very intolerant of movement (all manufacturers). But, if it is worse than usual, you may have a bad solder joint in the plugt or the socket. If you think this is the case, you should probably send it in.
