Reply To: Pitchfactor Expression Pedal Problem.
Home Forums Products Stompboxes Pitchfactor Expression Pedal Problem. Reply To: Pitchfactor Expression Pedal Problem.
#120706
air621
I've used several exp. pedals on my PF and none of them work well. So, I got the M Audio one that is suggested. It doesn't work either. When I set a parameter to change (for instance increasing the fuzz level on the octaver setting), it doesn't hold and just goes nuts and creates it's own setting. I've followed the manual. I'm wondering if there's something wrong with my PF
