Home Forums Products Stompboxes Pitchfactor Expression Pedal Problem. Reply To: Pitchfactor Expression Pedal Problem.
#120709
    air621:
    I'm wondering if there's something wrong with my PF
    This is possible, but unlikely. Much more likely are:
    1) bad cables- if you've tried different pedals, this may mean that you've also tried different cables, but if not ….
    2) bad connections – squirt a bit of switch cleaner (from local electrical store) onto the various plugs and work them back and forth a bit.
    If these fail, contact support@ventide.com
