Home Forums Products Rackmount S/PDIF converters Reply To: S/PDIF converters
#120723
Sound quality should be good. My guess is that you have a sample rate synchronization problem -either the Eclipse is not locked to the Digi card (make sure that the ext light is not flashing, if it is, check Setup/Digin/clock (p.25 of UM)), or the Digi card is not locked to the Eclipse output (discuss this with Digi). You also need to make sure that Protools is locked to the Digi card (discuss this with Digi).
One approach might be to set the Eclipse to Int 48K, and then sync Protools to the Eclipse's Word Clock output.
In short, using DAW software with external hardware is not simple …
