Home › Forums › Products › Stompboxes › TIMEFACTOR Update utility and bypass problem › Reply To: TIMEFACTOR Update utility and bypass problem
#120761
i make controll to all the bypass circuit that go in an optoisolator only and in dsp.
all work good, the pedal go in bypass mode when i try to change an effect with the encoder, but when i change effect the switch don't go in active with the  the led active on…
the machine pass the test in all the mode…this is only a software problem not hardware.
I try with other pc to upgrade the unit because with 3 pc i have all the experience of other user…
the pc in most cases don't see the unit but a midi speaker and the itility don't recognize the TIMEFACTOR….
this is all….
HI, to all
scuse my poor english!!!
