Home Forums Products Stompboxes IDEAs for Improvement on Pitchfactor Stombox Reply To: IDEAs for Improvement on Pitchfactor Stombox
#120796
    That a new one for me. The pots are below the panel, so dirt can't easily get into them.
    If you use your unit in a very grungy environment, presumably grit could build up underneath the knobs as you describe.
    The knobs can be pulled or levered off the shafts which would allow you to clean up if necessary or to allow more room for grit storage.
