Home Forums Products Stompboxes Can the PF midimap a preset and be programmed to TOG/BYP/ACT the same preset??? Reply To: Can the PF midimap a preset and be programmed to TOG/BYP/ACT the same preset???
#120798
No,what I'm asking is can the PF midimap a preset and then can the same preset be set to either Bypass,Active or Toggle ???
The manual says it can I believe but in my experience it can only do either or.
I have not been able to midimap a preset and then be able to set the Act/Byp/Tog selection.
The PF seems to be able to only access the Byp/Act/Tog function if you DON'T midimap the preset. If you follow the manuals instructions you can't access the B/A/T function once you midmap a preset you can only change the midimapping
