Home Forums Products Stompboxes MOD Factor volume very low to non existant in effects loop Reply To: MOD Factor volume very low to non existant in effects loop
#120805
achaput
    I'm guessing that you have a parallel effects loop. This type of effects loop mixes the dry signal with whatever effects are in the loop.
    A series effects loop, on the other hand, replaces the dry signal with whatever effects are in the loop.
    Delay effects work better with a parallel loop but modulation effects work better in a series loop (or between guitar and amp, as you discovered.)
    Some amps give you the ability to switch the type of effects loop, but others are 'hard-wired' one way or the other.
    If you are stuck with a parallel effects loop then your best bet is running ModFactor between guitar and amp.
    -Alan
