Home Forums Products Stompboxes Program Aux Switches same as Footswitches Reply To: Program Aux Switches same as Footswitches
#120973
ctc
    Thanks for the reply. But I don't understand…fully
    In order to duplicate the funtion of the foot switches (except for change from bank to play) each aux switch button must be able to be assigned 3 values, 1 for bank mode, 1 for play mode, and 1 for the looper. Is this possible to do?
    Also on pg 32 I see the instructions for programming the aux switches, but amongst the parameter destinations there is no select bank preset 1 or 2. How do you select a bank preset using the aux switch?
