Home › Forums › Products › Stompboxes › Midi Clock Problem with Timefactor->Modfactor › Reply To: Midi Clock Problem with Timefactor->Modfactor
Sorry Mate, but I don't get what you wanna tell me. Are you suggesting I should connect the Modfactor as a Master and the Timefactor as a Slave, midi-wise ?
If so, there is a reason I want to have the timefactor act as the clock-source, not the other way around … since the timefactor will be most of the time in Play mode for tapping and the Modfactor in various effect modes (bank mode). Plus, there are some effects like chorus where I don't want to tap the tempo (by turning Tempo Off), but that will only work when the Timefactor is Master, not vice versa …
Anymore suggestions ? Can someone with these two units check this out, please ?
