Reply To: Pitchfactor-no sound from pitch A knob on diatonic setting
Home Forums Products Stompboxes Pitchfactor-no sound from pitch A knob on diatonic setting Reply To: Pitchfactor-no sound from pitch A knob on diatonic setting
#121079
This sounds like such a specific problem that the cause is most likely in your external connections. Please check these carefully and replace cables where possible, etc.
If that does not help, and you are convinced it is the 'Factor, the first step would be to re-initialize it (see UM for info).
