Home Forums Products Stompboxes BYPASS VIA MIDI Reply To: BYPASS VIA MIDI
#121085
    Hi Nicola
    If I understand you, you want a relay bypass. So, after having carefully studied the User Manual
    1) set the [BYPASS][BYP TYP] to RLY.
    2) Assuming you want to use MIDI Program Change to select the bypass:
    edit the [MIDI][RCV MAP] to give you either OFF, ACT,TOG or BYP, depending on how you want to control it. These values are:
                   OFF   Unassigned
                    BYP    BYPass the unit
                    ACT    Make the unit Active, i.e. not bypassed.
    TOG   Toggle the between bypass and active.
