BYPASS VIA MIDI
Home Forums Products Stompboxes BYPASS VIA MIDI
Viewing 3 reply threads
    • #107421
      NickDeRossi
      Hello
      I need to recall bypass my TIMEFACTOR via "midi pedalboard"…
      I try to explane:
      I want a preset (ex 1:1) but trubypass (whitout any effect and direct in to out)!
      Is it possible?
      I set MY program change in this mood:
      CH1 – 1:1, CH2 – 1:2… ecc
      but I need a CHxx – BYPASS…
      (my MIDI Pedal Board is MIDIONE FLX-8)
      Sorry For my Englisch (…I'm from Italy)
      Thank You Very Much
      Nicola
    • #121085
      Hi Nicola
      If I understand you, you want a relay bypass. So, after having carefully studied the User Manual
      1) set the [BYPASS][BYP TYP] to RLY.
      2) Assuming you want to use MIDI Program Change to select the bypass:
      edit the [MIDI][RCV MAP] to give you either OFF, ACT,TOG or BYP, depending on how you want to control it. These values are:
                     OFF   Unassigned
                      BYP    BYPass the unit
                      ACT    Make the unit Active, i.e. not bypassed.
      TOG   Toggle the between bypass and active.
    • #121120
      NickDeRossi
      Thanks for the help but …in my spompbox, into the menu [MIDI][RCV MAP], i can choose only the number of preset or OFF!!
      Its' very strange…
      I Try to explane: This is the situation:
      CHn° > N°preset or OFF (not BYP, ACT or TOG)
      EX:
      0 to 127 > OFF to 20:2
      I have to download new software??
      Nicola
    • #132268
      You may have very old software which did not have this feature. Check the appropriate support page on the WebSite to see if there is an upgrade.
