Home › Forums › Products › Stompboxes › Small question regarding PitchFactor › Reply To: Small question regarding PitchFactor
#121090
Hi
If I got your question right, i believe this is easily done in Pitchfactor using the H910/949 algoritm.You can set your pitch increments (the amount by which the fundamental pitch of the signal gets multiplied) using the Pitch A and B knobs and the type of increment (micro , normal , chromatic ) using the Scale knob. Delays can be set for each of the pitch shifted sounds and you can also control their feedback.
Sincerel
Amey Rairikar
