Reply To: Timefactor colors / changes tone when activated
Home Forums Products Stompboxes Timefactor colors / changes tone when activated Reply To: Timefactor colors / changes tone when activated
#121230
7stringlespaul
Thanks.  I've tried kill dry on when I was using the parallel loop, it sounded terrible.  Like the way delay sounds before the amp with the amp's distortion turned on.  I have heard of a lot of you using kill dry on, but I just can't get it to work right with my Triple Rectifier.  Now I am using a new multi-watt recto with series loop, sounds a little bit better overall.
I guess I will get over the coloring of the tone when the pedal is activated, it's not as noticeable on my less gain channels.  This is really the best delay pedal around, just want it to have an analog tone.  Also with headphones on, I can hear a little bit of hiss too when activated, I guess that is just digital effects for you…
