Home Forums Products Stompboxes how are people getting 50 banks? Reply To: how are people getting 50 banks?
#121231
rabiddiabetic13
    After entering System mode, turn the Encoder to select
    [UTILITY], then press the Encoder to
    enter the Utility functions settings mode. Turn the
    Encoder to scroll through the following
    Utility functions. Press the Encoder
    to select and set:
    [BANKS] – Select
    the range of Active Preset Banks
    (1 – 50)
    Press the Encoder to select. Press the Left Footswitch to
    select the lower limit and the Right
    Footswitch to select the higher limit. Turn Encoder to
    set the lowest and the highest active
    banks. Only Presets saved in active Banks are available
    for loading using the Footswitches. All
    Presets may still be loaded using MIDI
    program change.
