Reply To: VSIG Inputs / Outputs
Home Forums Products Vsig and Preset Development VSIG Inputs / Outputs Reply To: VSIG Inputs / Outputs
#121275
Top Jimmy
Thanks. I see. Then to clarify,anything that is set under Orville's:
1) Programs>Routing
2) Setup>DSP (A/B) i/p routing
3) Setup>Outputs (Output Routing)
will be more of a hardwiring of the signal path? I assume this will not show up in VSIG? In VSIG I am really just viewing the DSP algo, and I guess it's independent of any routing options that were selected.
