VSIG Inputs / Outputs
Home Forums Products Vsig and Preset Development VSIG Inputs / Outputs
Viewing 3 reply threads
    • #107505
      Top Jimmy
      I'm new to using an Orville (upgraded from 7500). Since the manual states "DSP A has four inputs and four outputs, and DSP B has four inputs and four outputs", I was expecting to see 4 inputs in VSIG. I am only seeing 2 inputs and 2 outputs, similar to the 7500.
      Should I expect to see these 4 ins / outs in VSIG?
      This never made sense to me. If I have 2 analog ins that go to DSP A, why would it state that there are 4 ins and 4 outs, per DSP?
      Kindly,
      Jim
    • #121270
      Orville's HEAD module has a variable number of inputs and outputs. This number defaults to 2 for back-compatibility.
      Either edit the ninputs (noutputs) value, or use "Add Repeating Field" to change this number.
    • #121275
      Top Jimmy
      Thanks. I see. Then to clarify,anything that is set under Orville's:
      1) Programs>Routing
      2) Setup>DSP (A/B) i/p routing
      3) Setup>Outputs (Output Routing)
      will be more of a hardwiring of the signal path? I assume this will not show up in VSIG? In VSIG I am really just viewing the DSP algo, and I guess it's independent of any routing options that were selected.
    • #132426
      Top Jimmy:
      Correct – and only one of the two possibles. Vsig is essentially an algorithm designer.
