Home Forums Products Stompboxes Help – Program Transmit not functioning! Reply To: Help – Program Transmit not functioning!
#121320
I tried everything you suggested – still doesn't work!  Here's the entire MIDI section settings for both pedals – Timefactor is the controller – Modfactor is the slave:
                           TIMEFACTOR               MODFACTOR
RCV CH                   OMNI                                OMNI
XMT CH                     1                                         1
RCV CTL                 BYP<                                 BYP<
XMT CC                 PDL< C15                         PDL< C15
RCV MAP                1 < 1:1                                1 < 1:1
XMT MAP               1 < 1:1                                1 < 1:1
CTL XMT                   ON                                      OFF
PGM XMT                  ON                                      OFF
SYS ID                         1                                           1
OUTPUT                   XMT                                   THRU
CLK IN                      OFF                                     OFF
CLK OUT                  OFF                                     OFF
CLK FLT                    OFF                                    OFF
Hopefully it's ME that's doing something wrong!!!! Please let me know – I have a big show upcoming & would LOVE to control the MF with the TF.  I also have the Expression Pedal & 3 Button Aux Ftswch. that I can use to control both ala the Instructional Videos, but I've got to get the 2 pedals synched up first!
