Home › Forums › Products › Stompboxes › using Ground Control Pro w/ the Time Factor? › Reply To: using Ground Control Pro w/ the Time Factor?
January 9, 2011 at 9:25 pm
#121354
looking at the manual TAP TEMPO should be fine as the GCP has a "momentary" switch option, if you set the tap tempo button you want to be CC and momentary… you should be fine.
Looks like I will have to pick one up
