Home › Forums › Products › Stompboxes › Timefactor Multitap delay spacing not quite even? › Reply To: Timefactor Multitap delay spacing not quite even?
January 11, 2011 at 4:45 pm
#121378
Try putting the knob exactly in the center position to get perfectly spaced delays.If its not in the center then you mite get slight uneven spacing (even tho the display shows 5).Hope this helps
Amey Rairikar
