Home › Forums › Products › Stompboxes › PitchFactor: Fine tuning of delay times in V3b not happening? › Reply To: PitchFactor: Fine tuning of delay times in V3b not happening?
January 23, 2011 at 11:38 pm
#121464
Hi Brett
You were trying to use the fibonacci numbers, weren't you? I tried the same and it doesn't take 377 and also 610 it just gets close to. I can't actually tell if this was a problem before the update because I was using the tap tempo only. I noticed that if I use the tap tempo it does give me some numbers that i wouldn't get if I were manually dialing them in.
David
