Home Forums Products Stompboxes PitchFactor: Fine tuning of delay times in V3b not happening? Reply To: PitchFactor: Fine tuning of delay times in V3b not happening?
#121465
Burger666
    Davide Schachter:
    Hi Brett
    You were trying to use the fibonacci numbers, weren't you? I tried the same and it doesn't take 377 and also 610 it just gets close to. I can't actually tell if this was a problem before the update because I was using the tap tempo only. I noticed that if I use the tap tempo it does give me some numbers that i wouldn't get if I were manually dialing them in.
    David
    Spot on, David. It must be a bug and I have no doubt that our algorithmic benefactors are working on a fix right now. 🙂
