Home Forums Products Stompboxes TimeFactor settings problem with looper Reply To: TimeFactor settings problem with looper
#121474
Yes, it is. The expression pedal only changes the speed, not the depth. Also, the problem I'm describing happens even if you don't touch the expression pedal. Maybe someone with another TimeFactor can verify this? It's easier than I thought to replicate:
– Set Looper to Dom7ths, exp pedal to control speed only
– Write setting to a bank
– Change to another bank and back
– Turn depth knob to verify it's still on dom7th.
– Record loop.
– Stop loop.
– Turn depth knob and it will be set on octaves.
