Home › Forums › Products › Stompboxes › Can’t set Q-Wah completely off with expression pedal controlling intensity › Reply To: Can’t set Q-Wah completely off with expression pedal controlling intensity
January 27, 2011 at 8:09 pm
#121484
Thanks for the reply. I first UNassigned the exp pedal from Intensity. With the exp pedal assigned to NOTHING I find that the exp pedal still has an effect on the touch wah setup, my best description is that it affects the volume around maybe 15% or so. Then I assigned the exp pedal to Speed. It affects speed but does not disengage the wah sound at any setting. I'm looking for a way to defeat the touch wah completely with the exp pedal. Further ideas?
