Home › Forums › Products › Rackmount › Eventide H8000 : Trying to remote the levels and something wrong happens in the preset parametres › Reply To: Eventide H8000 : Trying to remote the levels and something wrong happens in the preset parametres
Yes, I have cleared internal prgs and set up already several times,with the 2 method described in the manual .
Take an Eventide H8000fw.
Set in Disp B an effect,by exemple ,"Galaxy borders2" ,or Polyring pre or whatever .
Set in Disp A a reverb, like Majestic Plate by exemple or Black hole.
In Disp B , assign the global parameters "Levels" in the remote control page to "volume". (with the select and hold method) . Now , with the midi pedal, you'll see and hear that the Wet/Dry mix of galaxy borders will go from 0 to 100% . In the "levels" page of the effect, all the 8 out channels are underlined.
Don't make any other remote assignments.
Tell me if you see now in the parameters of one of the 4 soft key of " galaxy borders" if a specific parameter does vary from his min to his max levels when you hit the pedal. It does !
Go now in disp A with processor A/B key , hit the vol pedal and see what happens in the parameter and levels pages of Majestic plate or Black hole .. you'll be surprised .
so easy !
Show More...EMP
