Home Forums Products Stompboxes Noisy Modfactor Reply To: Noisy Modfactor
#121618
    You should maybe set the level switches to guitar/amp. The level coming out of a pedal is usually much the same as that going in, so it's probably all guitar level.
    If you set the switches wrong you will get either noise (input too low) or distortion (input too high). You'll know …
