Home Forums Products Stompboxes expression pedal: no sound, but parameters on display changing Reply To: expression pedal: no sound, but parameters on display changing
#121690
HaloHalo0407
    To EVENTIDE staffs:
    Sorry for replying this old thread, but I pumped into the same problem.
    I plug in the exp pedal with stereo phone cable into the timefactor exp. jack, nothing changed whatever I roll the pedal. I unplug it and turn off the TF power, try to connect exp pedal then turn it on, it was still the same.
    I didn't connect any cable to the pedal except the one to the TF exp jack, and I tried adjust the vol setting knob on the korg pedal as well, it did not solve that.
    Here is the Korg xvp-10 user's manual I found on-line, maybe it will helped,
    http://www.korgpa.com/pa_root/pdf/accessories/XVP-10.pdf
    it's an expensive and nice crafted pedal, really hope it can work well with the TF, please help me. Thanks for your patience.
