Home Forums Products Stompboxes Noise – Stacking Eventide effects… Reply To: Noise – Stacking Eventide effects…
#121750
Randy7w777
    If you can run the pedals in loops thats the best the eventides amplify any slight noise sent to
    them they are not making the noise themselves. I run 2 Carvin v3 heads and a mod factor and a time factor im adding a pitch factor in a week. The best thing I'm also adding to my system
    that I suggest to all is a ISP Technologies Decimator Put that in a serial loop and kill all noise not tone my amp have parallel and series loops. I will run it as mod factor and pitch factor in parallel loops then ISP then time factor in serial loops. I should have no noise at all. The thing I like about an amp with both loops is the serial loop is the very last. If you put an ISP Decimator in your system
    make sure your delay is after it so it wont cut your delay but then its sent a clean signal then it wont
    make noise
