Home Forums Products Stompboxes funny power question Reply To: funny power question
#121800
    Hope you like it !!
    No stompboxes that I can immediately think of have a power switch – if you want to power it down you usually kill the power input to the power supply. Usually, you power all your kit down at the same time.
    If you just want to kill the effect, use BYPASS. The relay bypass setting gives a "true bypass", so the unit is in effect not there.
