Home Forums Products Stompboxes Controling multiple factors with Aux Switches & Exp Pedal Reply To: Controling multiple factors with Aux Switches & Exp Pedal
#121803
    If you (or someone you know) can make cables, you can delay MIDI lessons for a while.
    Essentially, you can make a 'Y' lead and connect the pedal and the aux switch to both boxes simultaneously. There is a faint risk of ground loops, but I assume you are using both boxes in the same setup.
