Home Forums Products Stompboxes Pitchfactor Stereo Output: A and B Harmonies Hard Panned? Reply To: Pitchfactor Stereo Output: A and B Harmonies Hard Panned?
#121829
DGillespie
    Hi Cro Aloha,
    Most of the algorithms in PF have two shifters.  In true stereo mode the A shifter is on the left channel, and the B shifter is on the right.  That is why they come out panned like that, because the box is true stereo.  If you want to do 3 part harmonies with both channels you should try Quadravox.  Set A and C to the first interval, then B and D to the second interval.  You will then have a true stereo 3 part harmony.
    Dan
