Home › Forums › Products › Rackmount › Factory Reset? › Reply To: Factory Reset?
March 29, 2011 at 8:19 pm
#121832
Here you go.
Initializing the Eclipse – erases user presets
With the Eclipse powered off, press and hold the 8 key and then power the unit on. It will load processing code; then the OS version; then it will say "Clear Internal Memory?" Select Yes. It will clear memory, initialize and then will load and display preset number 100 "Mute Series". This is to indicate the process is complete.
