Home Forums Products Stompboxes Space-Repeat/Hold Function Reply To: Space-Repeat/Hold Function
#122009
sjoplin
    Tim,
    thanks for the feedback, bottom line sounds like I can get the desired effect I'm looking for.  I currently use the RPT function on the TF quite a bit to lay down a quick pad effect, then play over top of it.  I've kept another delay in my setup so i can have some delay on the part that plays over the RPT signal.  So i'm looking to make sure I can do the pad type effect with Space, then use the TF to provide the delay on the lead lines……hope that al makes sense.
    it will allow me to remove a delay i've had in the system for a while.  I have the TF and PF so I'm sold on the sound quality of the Eventide boxes.
    thanks again,
    sean
