Home Forums Products Rackmount H8000 fw : abrupt effect disappearance when midi pedal is up Reply To: H8000 fw : abrupt effect disappearance when midi pedal is up
#122026
    Hi EMP
    Not quite sure what you are saying. If  you mean that the control is "non-linear", this may well be a function of the pedal – a pedal mainly used for volume control will probably have a logarithmic characteristic.
    If your Behringer works fine with Eclipse, try temporarily trying it with the H8000 to see if this is the difference.
